captain_MaTt
- Apr 18, 2006
is it possable to change the video card on a laptop?
if so where can i buy them?
um, NO!cyks said:You need to open the laptop. Just look for the PCI-e and take it out, put new one in. Newegg has some laptop cards I think.
I will take that 7900gtx 512mb off your hands if you wish.
Ice-Tea said:It does? Can you proove that?
Trimlock said:the XPS gen2's have the PSU's that can handle the 7800's and 7900's
sent my laptop in to get it upgraded to a 7800GTX go, they changed nothing other then the card, and also sent the 6800ultra back to me, thinking of what i can do with it ..., so etchy since the laptop costs 3k and this was the heart of it for so long.
Dell's MXM implementation is a little different than standard from what I recall... I doubt an adapter (if it even existed) would work on those cards...nobi125 said:I think I've seen adapters somewhere that let you use those in a PCI Express slot.
May have been something else entirely...
RadCliffeX said:i would LOVE to be able to upgrade the GPU in my ABS Mayhem G3, not sure if its possible. A 9700 mobile can only do so much![]()
lithium726 said:IIRC, the 9800m found its way into VERY few laptops, the most notable being the original XPS... which was a bohemith.
dell will prob release 1 video card upgrade on the xps 1710 chassis( maybe more if theycaptain_MaTt said:it's a new dell xps with a 512mb video card(7900gtx go) on a pci-e x16 slot.
