laptop Vid card question
sparky1_2007
So, i'm planning on getting a new alienware m5500 laptop soon, i was wondering if i should get the Go 6600 or the x1600 mobility..
I would like the Go 6600, because it'd take up less battery power, but if i get the x1600, it might take less, because of the 90nm fab process that it has.
Comments and criticism appreciated.
edit:
Also, here's the specs that i'm opting for...
BTW, it's an alienware M5500 laptop so if you wanna go configure your own to help you put down specs, be my guest..
Processor: Intel® Pentium® M 730 1.6GHz 2MB L2 Cache 533MHz FSB
Operating System (Office software not included): Genuine Microsoft® Windows® XP Professional with Service Pack 2
Warranty: 90-Day AlienCare Toll-Free 24/7 Phone Support
Display: Alienware® m5500 15.4" WideSXGA+ 1680 x 1050 LCD - Xeno Grey
Motherboard: Alienware® Intel® 915GM + ICH6 Chipset
Wireless Network Card: Intel® PRO/Wireless 2915 a/b/g Wireless Card
Memory: 1GB Dual Channel DDR2 SO-DIMM at 533MHz - 2 x 512MB
Hard Drive: 80GB 7200 RPM ATA100
Video/Graphics Card: 256MB NVidia® GeForce™ Go MXM 6600
Sound Card: Intel® High-Definition Audio
Additional Battery: Alienware® m5500 9-cell Lithium-Ion Additional Battery
Optical Drive: 8X Dual Layer DVD+/-RW / 24X CD-RW Combo w/Software
Ethernet NIC: Integrated High Performance Gigabit Ethernet
Modem: 56K Modem with V.90 Technology
Flash Memory: Kingston® 1GB CompactFlash Card
AlienRespawn: Alienware® Respawn Recovery Kit
I went to Alienware's website to check this out. And the fact that you can choose a 1900x1200 15.4 inch screen is awesome! I would buy that if it weren't for the crumby processor. They really aught to offer the new intel Duo processor in a 15.4 inch. It costs the same.
Oh, and about your question, I would definitely go with the X1600. It's a personal preference yes, but I've played with both... so it has some validity? Doesn't it? ;)
Why Alienware? I lost interest after reading about the 90 day warranty, that's not nearly enough...
Still, I'd go with the X1600.
Get a 9300/e1705, buy a 7800gtx go off ebay or forums, walla you have a much better laptop rig for prob around the same cost as that alienware.
do that...
if not then the x1600 has better performance
