Laptop SSD Replacement
demechman
Can anyone share some advice on what to look for when attempting this operation?
I am planning on purchasing a new laptop around $950 and replacing/adding an SSD as the boot drive. I have not landed on a specific model so I am wide open on options. My concerns are as follows.
  • SSD Interface (IDE or SATA) - just me not having ever worked on a laptop
  • Power requirements
  • Size recommendation
  • Brand?
  • Any other issues not thought of?
1) SATA.
2) Powered by SATA.
3) Standard 2.5" 9.5mm height, unless you have a mini or superthin laptop that requires a 1.8" SSD.
4) SSDs currently are lower capacity for more $$$, so a good one will likely run you between 25%-50% of the total cost of your laptop.
5) Intel "G2" 80 GB or 160 GB.
6) Run the SSD on AHCI, not IDE; make sure this laptop has SATA II support to realize maximum SSD performance; check here in the forum for appropriate tweaks to get the most life and performance out of the drive.
7) But is it worth it? It's the single best upgrade for a laptop imho. Once you go SSD, all else'll be memory.
What is the best way to verify the internal connections on a laptop you do not have in person. Would it be best to buy the laptop then buy the SSD?
