GodsMadClown said:I think the Total bithead is your typoe of unit. I've never heard it, however. I seem to recall that MisterX didn't like it.
Can you see the problem with posting second hand opions about products you have never used?Yea, I didn't recommend the bithead because I've heard a lot of negative stuff about it at Head-fi. However, they are really picky over there, so who knows =].
Mister X said:Can you see the problem with posting second hand opions about products you have never used?
How about you try something new?
Restrict your recommendations/comments to products that you have actually used and you won't have to worry about dealing with that kind of nonsense.![]()
Nope, I pretty much gave up rightmark testing stuff cause it doesn't really tell you how something will sound.ooze said:Thanks, the UA-25 looks interesting. Did you rightmark the UA-25 at all? If so, how did it compare?
That was my big issue with it.... well, that and it wasn't entirely as portable as I would have liked.ooze said:The only other thing is that it seems to have a lot of other stuff on it which I would never use.
Good question.ooze said:Isn't there like a non recording version of things like these?
