Laptop questions
beachnut
I purchased this Laptop for $699. Was this a good deal and how does it compare to a Turion ML-32 equipped the same and priced at $799?
Gateway MX7120 Notebook
The Gateway MX7120 notebook is powered by the AMD Mobile Athlon™ 64 processor 3400+ that delivers leading-edge 32-bit and 64-bit application performance.
* 2.2Ghz AMD Mobile Athlon™ 64 Processor 3400+
* 15.4" Widescreen Ultrabright™ WXGA TFT Display
* 512MB DDR Memory
* ATI Radeon® Xpress 200M Chipset
* Integrated ATI Radeon® X300 based graphics
* 100GB Hard Drive
* DVD+/-RW Multi-Format Double Layer
* Microsoft ® Windows® XP Media Center Edition 2005
* 1 Year Warranty Parts and Labor
* Weight 7.5lbs.
Do you transport it with the battery in the laptop?
Who makes good laptop cases? This is my first laptop, hence the questions.
Yes, you may transport with the battery in...I don't think I've ever really taken the battery OUT of mine.
As far as cases go...guess it depends on what type of traveling you do. I have this one:
http://www.targus.com/us/product_details.asp?sku=TSB312
It has plenty of room for everything I need and is very comfortable. I am also very active so only a backpack solution would work for me...
