haste
- Sep 27, 2005
was this installed correctly?
the area that is circled is the contact point for the gpu on the motherboard. the CPU had regular old TIM installed. the gpu had a piece of "foil" over the TIM between it and the surface of the GPU.
these two pictures are with the foil still intact on the gpu heatsink. u can see the color difference between it and the cpu contact point.
i removed the foil and found a whole layer of TIM. is this normal?
first time ive ever taken a laptop apart, so im curious...
thanks!
thanks!
