Laptop Overheating?!?!?
Beave
i have a hp laptop that i believe is getting too hot and just turns off
it is an amdk-7; and i am have not been able to install windows because it just randomly shuts off; how can i kool it down i have already gotten fans on the bottom of the laptop
i was thinking that i would use a monitor instead of the lcd maybe that would kool it off
anyother cooling solutions would be great :)
Raise the laptop with legos or something (put a lego piece on each corner) that's what I did with my laptop and it dropped in temp by a few degrees, also the fan doesn't startup every time I play solitaire (it's really old)
i got windows to install wooot!!! :D :D :D :D
just wondering what was the program that kept the cpu fan always running i dont rember it thanks
