shadowbreaker513
- Feb 15, 2005
I have a PIII Dell Latitude CPx laptop that I bought used. After a while, the kyboard startd crapping out. spciaally the e ky as you can probably see from me typing this post. I figurd since I bought it used, I didn't haave a warrenty, and I didn't know dll had issssud a freee fix for kyboards on thir laptopss. I just figured that a cable insid was loose, so I opnd it up and checkd th connections. I repluggeed everything in, except there was a problm with on of the cabls. As I know now, it was the cable for thee touchpad. It wass a small, red sata looking cable. The actual cable part camee out of the plastic plug on th end. I tried to reconnect it, but it didn't work obviously. Now the touchpad doesn't work, th pointing sstick doesn't work, and a usb or ps2 mouse doesnt't work. I can see the cable making th touchpad and the sstick not work, but not external mouses. Is there anything can I do save takee it to a shop? Considering I neeed this problem fixd, th keyboard fixed, and th computr locks up wheeneever I plug something into the cardbuss port (happend beforee I opneed it), is it evn worth paying th $80 initial fre just for somebody to look at it and theen $40 per hour for the overpriced placess around hr to fix it? Or should I justlive with tabbing everything and typing almost illegibly lik this. Or is thre any way that I can fix this myself. (built two mATX computers,nveer workedon a lappy)
