Jul 21, 2005 #1 T Tristezza Weaksauce Joined Jul 13, 2005 Messages 120 I have like 3 perfectly working laptop LCDs around and was wodering if there is anyway I can hook them up to desktops using some kind of crazy adapter or mod or something. Does anyone know is can be done?
Jul 21, 2005 #2 M MovieMan80 Limp Gawd Joined May 31, 2002 Messages 384 It can be done but it's usually not worth the trouble. Check out www.earthlcd.com For the cost and time setting up the panels, you're better off buying a new lcd.
