Laptop IDE..convert to PC SATA?
ThreeDee
is there an adapter that does this in one go ..or would a guy have to combine something like this and this ?
Are you looking for something that's a long term solution or do you just need one-time access?
It's not clear to me... do you want to access the sata drive from the laptop or the laptop ide drive from a sata port on a different computer?
If it's short term use you might use something like this.
laptop IDE drive (old 20gb) ..convert to SATA to run in a PC in a box that is going to be a dedicated firewall
you could use to adapters a standerd laptop ide to ps ide the use the abit serillel to take the ide to sata
I'm trying to steer away from the wider ide cables if possible .. plus the semi-geek factor involved
It's going to be more complicated and therefore less reliable to do it the way you want to. The adapter I referenced is just a connector, no logic involved. Going from IDE to SATA or USB involves a bridge chip. At the cost you're looking at you may as well find a used cheap SATA drive.
That said, your easiest way to get this done will probably be to use something like the IDE to USB device linked above by tgmorris99 and connect it to one of the internal USB headers on the motherboard.
Dustin
