Laptop HDD interface unknown, any ideas?
Hello everyone,
I bought a used Dell Lattitude CPX to build a digital picture frame with. I want to remove the harddrive and replace it with a flash part. My original idea was to get a $20 IDE to Compact Flash adapter, however, my laptop isn't IDE and I'm not really sure what it is. It might be some kind of mini-SCSI. Here is a link to a picture of the interface
Does anyone know what that interface is?
The drive itself is some kind of mini-IDE, and the drive bay converts the mystery interface to mini-IDE, here is a picture of that.
I guess I can always do this.
mystery interface -> mini-IDE - using the drive bay itself
mini-IDE -> IDE - I'm assuming I can find that adapter online somewhere
IDE -> Compact Flash - I've seen these adapters around for about $20
Am I overlooking something? With all of these connectors is there any problem getting power to the flash chip?
Thanks in advance!
//Rob
Do that then get the IDE converter for the compact flash. That connector is just some proprietary one that dell came up with because, well its a dell.
It prevents the drive pins from getting bent while installing and uninstalling the drive.
Ah, i see i just assumed it was a dell proprietary thing.
No, many notebooks use the same idea (different connector, though). Toshiba, IBM, HP/Compaq...
