Laptop for work ~$700
BeavermanA
Starting a new job soon, part of my negotiations included a new laptop.
Think I'm comfortable with ~$700. Didn't give me a set limit, but I'm not going to get some ridiculous expensive gaming laptop.
I'd like:
1080p
15.6" max
Good battery life
Light weight
Can be from Newegg, Amazon, Best Buy etc.
I'd even be open to some kind of MS Surface tablet with the keyboard attachment. Be nice to be very low weight and easily carried. Do need Windows though.
Posting cause I don't have a whole lot of time to thoroughly research all options. Wants me to email tonight with my selection.
Surface Pro 2 with the keyboard cover and an extra monitor. It will be out of your $700 budget. Will probably be closer to $1200 total. But, you get the portability of the Surface Pro 2. You get the added usability of the Surface Pro 2 (compared to an iPad or a Mac). You can actually do work on the the Surface Pro 2 (compared to RT, ibathroom, etc). And, you can dock your Surface Pro 2 and use it with the bigger screen.
Look at it this way, for the same price that apple charges for a refusebook, you get a whole lot more. And I can be this honest about the fruit company because I own a Macbook Pro with the higher resolution screen (retina is a misnomer), use OS X, Windows, and Linux extensively both personally and for work. And when I first started, I asked for a Macbook and it was a huge mistake.
This has been both an informative post and a rant. And now my weight has been lifted. Thank you for reading. :)
