Laptop for my sister.
ElevenFingers
Hi,
I'm back and once again looking for some expert advice on getting something I don't know much about. My sister is looking for a new laptop for college and would like to choose from a couple of options.
Her requirements are as follows:
- Lightweight
- Large Screen (Lightweight being more important)
- Can Handle Sims 3 on full Graphics
- is 'Cute'
You can ignore the 'cute' part. I'm looking for efficiency. It should be able to handle Vista effortlessly so that it loads quickly on start up and so on. She's impatient and she'll be likely to take more care of a laptop she actually likes.
Anyhow, I was considering this model for her. What do you guys think and do you have any other suggestions? There isn't really a price-ceiling but my parents also don't want to spend money inefficiently. I'm looking for the best buy currently out their. If I don't have it done quickly she will go to our local version of Best Buy and ask the help about their 'deals'. *Shudder*
So yeah, thanks for considering this post and for your time. I really appreciate it.
~Eleven Fingers
It will do the trick. Just make sure that the onboard GPU is better than a GeForce 8xxx or a Mobility Radeon HD 2xxx GPU (which fits the description of the 9300M GS in that laptop).
Absolutely hate HPs. 100% glossy surfaces, maybe more. But if this shit is cute then I suppose.
Your questions are better asked here @ notebookreview
http://forum.notebookreview.com/forumdisplay.php?f=16
This is what they ask:
General Questions
1) What is your budget?
2) What size notebook would you prefer?
a. Netbook; 10” screen or less
b. Ultraportable; 11" - 12” screen
c. Thin and Light; 13" - 14" screen
d. Mainstream; 15" - 16" screen
e. Desktop Replacement; 17"+ screen
3) Where will you buying this notebook? You can select the flag of your country as an indicator.
4) Are there any brands that you prefer or any you really don't like?
a. Like:
b. Dislike:
5) What are the primary tasks will you be performing with this notebook?
6) Will you be taking the notebook with you to different places, leaving it on your desk or both?
7) Will you be playing games on it; if so, which games or types of games?
8) How many hours of battery life do you need?
9) Would you prefer to see the notebooks you're considering before purchasing it or buying a notebook on-line without seeing it is OK?
10) What OS do you prefer? Windows (XP or Vista), Mac OS, Linux, etc.
She's most likely going to cover it with stickers and stuff. For now I'm looking for efficient systems. Thanks for the link and the help so far.
You might want to get a 9600M at least. I don't know if the 9300M is enough. You should double check if it is.
