Laptop for business student?
Ummm
What laptop would you recommend for a business student?
I would want a laptop that has a long battery life (4hrs+), WIFI, CD/DVD burner and 2GB+ ram with 160GB+ HDD. I want this laptop to last at least for 4 years. My budget is $1500, but I'd like to find a laptop for under $1000.
I'm also looking for a silent (no humming), fast loading/starting programs/files and non-overheating (don't want it extremely hot) laptop.
Check your school for any discounts. If they don't do any that you like I recommend a Lenovo T, R, or X Thinkpad series laptop depending on what you want to do with it. Lenovo gives a 5% discount to students I believe, and they do sales pretty often online. The keyboards are nice to type on and the machines are built well.
Lenovo Thinkpad T61. Spec'd out as you've requested, I've got it at $1150 with a 14" screen or a little more with a 15". It burns DVDs and has 2GB RAM, a 160GB HD, a Penryn processor, and a nine-cell battery for long run times. It's also as well-built as laptops come.
You can also get some cash back through a few websites, probably around $50-100, and if you wait a little longer, I'm sure a significant coupon will show up. Over the last month there have been two 20-25% off coupons on ecoupons.com, and I'm sure there will be more. That will get the price well under $1000.
I've got a Sony Vaio VGN-C140g with features that you are looking for, PM me if you are interested.
I've chosen to go with Lenovon laptops, now I need to choose between the 3 laptops:
R 61 ($1904):
http://i169.photobucket.com/albums/u233/macleef/Lenovo-R61Customized.png
T 61p ($2090):
http://i169.photobucket.com/albums/u233/macleef/Lenovo-T61pCustomized.png
T 61 ($1979):
http://i169.photobucket.com/albums/u233/macleef/Lenovo-T61Customized.png
By the way, what's the difference between Express Card Slots, Media Card slots and Smart Card Slots?
Is it really necessary to have Intel Turbo Memory 1GB and Gemplus GemPC400 Compact Smart Card Reader?
Which Wifi wireless adapter should I get (I don't know the difference between the three)?:
Intel PRO/Wireless 3945ABG
ThinkPad 11a/b/g Wi-Fi wireless LAN Mini-PCIe
Intel Wireless WiFi Link 4965AGN (I picked this one, I don't know why)
Should I get the basic warranty or more?
I'd go with a T61P, Penryn CPU, (upgrade your RAM from newegg or something to save money) and a 72k rpm drive. Don't bother with the turbo memory junk, you don't need it and it does not work well either. I'd say go with the Intel Wireless WiFi Link 4965AGN for the N support. If you can afford it, go ahead and upgrade the warranty, the T series are built like tanks but after 4 years, who knows, it couldn't hurt.
Expresscard is like a newer form of PCMCIA. It's for expansion cards--if you've ever had an old laptop without wireless built in, you had to plug in a PC card. Expresscard is that, but newer.
Media cards are like SD, xD, CompactFlash cards, etc. They store files. Cameras usually store photos on them, and now computers can read them.
If you've got 4GB of RAM, you won't need the Turbo Memory. It won't help you much, if at all. It has caused problems for others in the past. I'd skip it. On the same note, I'd also recommend buying some of your RAM separately and installing it yourself. You will probably save money. Order 2GB of RAM in 1 DIMM and buy 2 GB in one DIMM separately, online or in a store. Installing it amounts to ninety seconds of work and is easy even for the computer squeamish. This will probably save you ~$50, though Lenovo is more reasonable about RAM prices than other manufacturers.
I almost guarantee you you don't need a smart card reader. Don't buy it.
The AGN adapter is the most "future-proof" because it supports the Wireless-N standard, which is like the current generation of Wi-Fi, but faster. I also bought the AGN adapter with my Thinkpad because I figure I'm going to keep it for a while.
You can extend your warranty coverage towards the end of one year if you think you'll need it. I'd stick with the basic warranty and then decide in a year if you feel it's necessary to add more.
What are you planning on using this laptop for? The T61p you've got configured has a very powerful graphics processor, the R61 has a middling GPU, and the regular T61 has the most basic one. If you're doing a lot of gaming or CAD work, the T61p is the only way to go, but otherwise you should be fine with the integrated graphics chip. It will save you money, heat, and battery life.
How do I get Lenovo to give me student discount? (I'm Canadian by the way)
In the US you just select the education link, but it seems that there is not one on the Canadian site so you might have to call them and see if they will give you an extra percentage off. Hopefully you can get the student discount as well. You will be happy with your Lenovo machine, and it should last you. Good luck on your purchase and enjoy your new machine.
You can get a 2.4ghz 8600gt,4 gig ram, Dell XPS 1530, for about 1600$, if you use discounts, ill go with that if i was you.
I'm looking for a light-weight laptop (14.1", around 4 to 5.6 lbs)
Does anyone know how's the customer service for Lenovo in Canada and how long it takes to deliver the product?
Then go for the XPS 1330, i tried the 350$ off cupons but they expired, they usually have new 1s every week or 2, so if you can wait you might be able to get something like,
XPS M1330
Intel® Core™ 2 Duo T8300 (2.4GHz/800Mhz FSB/3MB cache)
Genuine Windows Vista® Home Premium Edition
System Color Tuxedo Black
Memory 4GB Shared Dual Channel DDR2 SDRAM at 667MHz 4GB
LCD and Camera Slim and Light LED Display with VGA Webcam
128MB NVIDIA® GeForce™ 8400M GS
320GB SATA Hard Drive (5400RPM)]
(DVD+/-RW Drive) 8XDVDRW
Integrated Sound Blaster Audigy HD Software Edition
Intel Next-Gen Wireless-N Mini-card
56Whr Lithium Ion Battery (6 cell)
Fingerprint Reader
Camera Panel Slim and Light LCD with Tuxedo Black Casing and Camera XPS M1330
For about 1700$ and if you change the ram to 2gb you could save 100$, and if u make the HD only 200gb, you can save another 100$.
The Thinkpad sounds right for you...too bad you're in Canada.
Though I received my own Thinkpad in less than a week, pretty heavily configured, Canadians often complain about their computers taking much longer to arrive and about poor service from Lenovo Canada. I hope to never have to deal with the warranty folks, but if I do, I feel confident that I'll have a pretty smooth transaction. Canadians, I'm not so sure.
Lenovo is pretty good unless you buy when a new laptop comes out the wait time is usually about 1 to 2 weeks to get your system I believe. I don't know how well the Canadian service is but if you have complaints then you can post them at forum.lenovo.com and they will try to help you. Lenovo's are built better than any other laptop that I have used, and at least in the US the service turn around is usually less than a week (Lenovo service sending you a box pre-labeled back to them they fix it and send it back to you). I know this from dealing with warranty three times, my tablet had problems but they took care of all the problems and the machine is now like new. Lenovo usually outsources its service to a company in the country that you live to fix your machine. For the most part Thinkpad's usually don't need to go in for repairs, because of their build quality and built in protections (ie roll cage). Good luck on your purchase.
XPS M1330
Fingerprint Reader
This is what I did for my wife, she's finishing up her MBA right now, which is what this was purchased for. Make sure you call Dell and talk to a rep, you can talk them down in price. I got it before the 45 nm were released but it has the exact same specs with a T7500, without the soundblaster card and only 3 gb of ram. Got 4 year complete care and lojack as well and a $70 gift card on top of that. I managed to keep it just under the $1500 price point.
Quantity Item Number Description Unit Price
1 222-9693 XPS M1330, Intel Core 2 Duo Processor T7500 (2.2GHz/800MhzFSB, 4M L2 Cache) $1030.44
1 320-6009 Alpine White Color with Gloss $0.00
1 311-7638 3GB, DDR2, 667MHz 2 Dimm $0.00
1 320-5583 13.3 Inch Wide Screen WXGA TL WLED Backlit LCD with Camera, XPS M1330 $0.00
1 320-5603 128MB NVIDIA GeForce 8400M GS, for XPS M1330 $0.00
1 341-5709 320G 5400RPM SAMSUNG Hard Drive $0.00
1 420-6813 Microsoft Windows Vista Home Premium Edition, English $0.00
1 420-7098 Media Direct 3.3 $0.00
1 420-5769 Internet Search and Portal $0.00
1 420-5924 Icon Consolidation Application $0.00
1 420-6436 Vista, PC-Restore, Dim/Insp $0.00
1 463-2282 Dell Owners Manual installed on your system,click on icon after system set-up to access $0.00
1 420-7387 DELL RESOURCE DVD,BACK-UP XPS-M1330 $0.00
1 412-0946 Dell Travel ExpressCard Remote Control, IR $0.00
1 310-9246 Creative Earbud EP630 $0.00
1 420-7622 DELL SUPPORT CENTER 2.0 $0.00
1 430-2600 Integrated 10/100 Network Card $0.00
1 420-7468 ADOBE ACROBAT READER 8.1 DIM/INSP $0.00
1 313-5361 8X DVD+/-RW Slot Load Drive for XPSM1330 $0.00
1 313-4783 Integrated High Definition Audio 2.0 $0.00
1 430-2577 Intel 4965AGN Wireless-N Mini Card $0.00
1 461-8389 No Virus Protection Requested $0.00
1 312-0561 56 WHr 6-cell Lithium Ion Primary Battery, for XPS M1330 $0.00
1 412-0148 No Internet Service Provider Requested $0.00
1 412-1397 No Productivity Software requested $0.00
1 950-7447 4 Year Limited Warranty $0.00
1 412-0359 Soft Contracts - Qualxserve $0.00
1 980-4063 Type 15- Third Party At Home Service with Nights and Week ends, 24x7 Technical Support, 3 Year Extended $0.00
1 987-6358 Dell Hardware Warranty PlusOnsite Service, Extended Year(s) $0.00
1 983-3710 Type 15- Third Party At Home Service with Nights and Week ends, 24x7 Technical Support, Initial Year $0.00
1 987-6357 Dell Hardware Warranty PlusOnsite Service, Initial Year $189
1 464-5100 $70 Promotional Gift Card arrives in 6-8 weeks. Redeem before 1 year expiration at www.dell.com/epp/giftcard $0.00
1 902-2483 Warranty Support,3 Year Extended $0.00
1 960-8710 Warranty Support,Initial Year $0.00
1 412-0358 Soft Contracts - Consumer Complete Care $0.00
1 960-9189 CompleteCare Accidental DamageProtection, Inspiron, 4 Year $99
1 988-0689 Bundle LoJack Theft Recovery Service - 4Year $50
1 430-2566 Dell Wirless 355 Bluetooth Module (2.0+EDR) $20
1 310-9273 Fingerprint Reader $0.00
1 466-8039 Thank you for choosing Dell $0.00
1 310-9348 Intel Centrino Core Duo Processor $0.00
1 310-8628 You have chosen a Windows Vista Premium System $0.00
1 320-6149 Slim and Light LCD with AlpineWhite High Gloss Casing and Camera XPS M1330 $0.00
1 464-9572 No Entertainment software pre-installed $0.00
1 420-7091 DataSafe Online Dim/Ins/XPS $0.00
1 420-7285 Datasafe Online 10GB,1 Year Free $0.00
1 987-7449 XPS,Datasafe 10GB,1YR(Incl w/price) $0.00
1 988-0099 To activate your online backupaccount, go to Start, Programs, DataSafe Online $0.00
Order shipped email signup
Sub-Total : $1388.44
Tax : $111.30
Order Total : $1499.74
lenovo.com/cpp
556655
Thank me later
For friends and family of people that work at lenovo. You're a friend of my uncle, if you ask me!
lenovo.com/cpp
556655
Thank me later
That's for US...and does Lenovo (in US) cancel orders to those who use CPP (and are suspicious the customers do not know any IBM employees)?
Also, are there monthly payments for Lenovo Canada? (Can someone please check for me? When I was viewing the shopping cart, I didn't see any payment options like US has?)
