Laptop Drive to USB adapter
Ur_Mom
I bought a USB adapter that can go from IDE/SATA and Laptop IDE to USB. Everything works great. EXCEPT when I hook up the laptop IDE drive. It can read/write for about 5 minutes (more like 2), then it shuts down. I'm not sure if it is a power saving feature or what, but it is annoying. I have changed the setting in Device Manager to "Allow the OS to shut off device to save power" to disabled with no results.
Anyone have a similar experience or solution. Yes, I've Googled it many times under different queries with no decent results. I don't think buying a new one would help, as it does work, it's just the power to the HDD stops after a few minutes.
Grrrr.
Where is it getting it's power from? Directly from the USB port, or is there an AC Adapter with it? It may be that the IDE/PATA drive is trying to pull too much power from the USB port, so it is getting shut off as a result.
It is getting it from the USB port. That may be what it happening. It does it when copying the files off of it. I'm just going to throw it in old laptop and boot from a Linux CD and copy over the network for a backup...
Thanks, man. :)
