laptop cooling
faze
I just got an IBM thinkpad and the thing seems to run really hot. I'm not sure if this is normal but i felt the hard drive (took the slot cover off) and it seems to be really hot, maybe 120-130 degrees F. is this normal? or is the hard drive bad. I'm really not sure what it could be, if anything, in fact, is wrong.
On all the laptops that I have used, especially the ones that have a small casing, everything tends to heat up more. If everything is functioning fine then it should be ok.
