I have a Dell Inspiron 6400 laptop. I few months ago I tore it down for a learning experience and while I was in there decided to replace the dell cpu tim with AS5. for the past couple months the cpu has been running fine and have been monitoring the temps. Then I started folding again with the laptop and now even with the fan setting at a continuous high setting (which is loud), the laptop cpu is consistently hitting 65C degrees. Without load is typically hovers around 40C with speedstep enabled.
Does anyone have any suggestions how to cool her off a bit better?
