Will it be able to scale 2 displays differently?Windows 10, although it is not yet fully released, appears to support scaling quite well.
From what I have heard, yes. However, I have not done so myself but I can test it tonight if you want. (I just upgraded to a 4k 28 inch monitor but have not sold my 27 inch 1080p monitors yet.)
Really difficult question that is all over the place .I will let you know. Probably not until late tonight but, it will be an interesting experiment.
Edit: What would your response be to the questions I have in this post please? Thanks: http://hardforum.com/showpost.php?p=1041698006&postcount=40
For gaming => 1080p with a 290, 1440p max. With FuryX/980ti you could go 4K with good framrates; be sure to buy an IPS one if you want the best "looks" (obviously otherwise you wouldn't want 4K). Very little experience with Eyefinity myself for gaming.
For productivity=> 2/3 displays are much better than 1 4K display. I also ordered a Dell 34", which will be a good middle ground between 2x 27" and a 4K display.
Thanks for trying it out, all my spare systems are currently in use as we are hiring some people for a big project, otherwise I would already have a windows 10 system up and running to test it out myself.
Well, I plugged in my LG 27 inch 1080p monitor in the HDMI port of my R9 290 card as a secondary monitor. It immediately detected it and used the 100% scaling automatically at 1080p resolution. The 4k monitor had automatically set itself at 150% when I plugged in last Friday night. At least with Windows 10, automatic scaling works well.
