2.75 x 4.5 sheets of wet-or-dry sandpaper
- 4 sheets of 220 grit
- 4 sheets of 400 grit
- 4 sheets of 800 grit
- 4 sheets of 1200 grit
- 4 sheets of 2000 grit
- 4 sheets of 2500 grit
One (1) 3" x 4" lapping surface
Just got my sandpaper lapping kit today.
I'm having trouble finding which one is the 220 grit? Is it the really rough one?
They get smoother as I go up right?
I plan on lapping today, and need some tips on how to do it right and make the surface as flat as possible.
From reading many lapping guides I picked up these little tricks
taping the sand paper to a glass and lapping it like that
the credit card and razerblade method to determine the flatness
coloring the surface with a sharpie
any more that I can add?
Also which layers am I going to have to sand off? What colors are they?
One drop of water is enough to wet the paper?and how much time should I spend on each grit?
I'll be lapping the heatsink first then my CPU.
Tuniq Tower 120 and Q6600.
