Lapping my Q9550 CPU & HSF base
Itshondo
I've been working on getting the temps down on my Q9550, so I decided today that I'd lapp the CPU and the base of my HSF. I also thought I'd document how I did it.
First I used a piece of glass as the lapping area. I taped it's corners to the table -
Then I tape the corners of the sandpaper to the glass, making sure that it is flat & taught -
My plans for lapping will be in 4 grit stages - 220, 320, 600 & 1500.
Now I needed to mount my 9550 to a piece of foam. This will do 2 things -
- provide a nice base to grasp the cpu,
- protect the bottom of the cpu from the metal removed from the cpu's heatspreader.
Here's the foam & cpu -
Sitting on the foam with the edges carefully taped to keep the 2 pieces together -
My cpu's Identification, pre lapping -
The HSF had been previously lapped but this raw cpu put corner indentations into the base -
I used the "Figure 8" method to lapp the cpu on WET sandpaper. I sprinkle & spread a little bit of water on the paper to help lubricate the paper & prevent metal dust from getting airbourne.
After the 220 grit -
the 320 -
the 600 -
and the 1500 -
And a "screen shot" -
Not quite a mirror finish but a VERY flat & smooth one that will ensure that maximum heat will be transfered to the HSF.
Tomorrow I'll be installing a new Prolimatech Megahalems heatsink & a 120 mm fan- I hope that it's base is flat.
Looks good. I usually start with 600 - 800 - 1000 - 2000. Leaves a mirror finish and 600 doesn't quite scratch as bad as the lower grits. The main thing is flatness - not reflectivity , though.
