Eastcoasthandle
- Jan 27, 2006
Make sure you remove the 2 screws to the left in order to remove the HS cover or else you cannot remove the HS.
Here is a photo of the HS as you can see the mosfet HS is also incorporated.
In these photos you will see what looks like drill (milling) markings on the HS. It's not as bad as the X1900XTX that I showed sometime ago. However, they are there so a decent lap maybe appropriate.
Dry lapping with 2000 grit sandpaper appears more appropriate then anything else. As you can see the results I was able to remove the drill marks without removing much else.
Temps idle and load playing a game.Ambient temps around 22C
