Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
i read that one of the mounting holes is an extremly tight affair with that mobo, and i was wondering if anyone has been able to mount any blocks on it?
Well don't forget you don't need mounting holes to get a block like the Swiftech MCW500x series on there. These are perfectly good waterblocks, so not all is lost
I don't have any mounting holes on my damn MSI board
If you wnat mounting holes on your Lan-Party NFII board, make sure you get the "B" revision.
I have the A revision, and don't have these holes. I managed to get away with using a swiftech 5000 waterblock with no problems. I'd rather be using a whitewater though, but I can live with this board just fine.
