Lanparty NF4 fan dying
Kyohe
So, the fan on my mobo has started making a terrible grinding sound. Here is the board:
http://us.dfi.com.tw/Upload/Product_Picture/LP nF4 SLI-DR.jpg
It's the fan with "DFI" on it. I was looking at something like
http://www.newegg.com/Product/Product.aspx?Item=N82E16835110103
To replace it. My biggest concern is that the fan I have now is SNUG with the edge of my video card. So I don't want to get a fan that's any taller than the one I have. I was hoping someone might have a suggestion or advice for what fan to get. Thanks.
I bought my EVERCOOL EC-VC-RE from Jab-tech.. It ran like a champ!!!!!!!!! Best $7 bux spent on my DFI nF4 Lanparty board!
Thanks! I just ordered the fan from Jab-tech. I look forward to having a nice quiet computer again.
Ok, so the fan arrived and with a fair amount of hassle (it blocks my vid card now) I got it installed. It seems to be running at a constant 41c, which is good. It used to be at 46c. I'm wondering about the 3pin to 4pin power adapter. I'm not using it right now, and the LEDs look really weak. Should I use the 4pin plug? Will that make it work better? Or, what is it there for? Thanks.
