Lanparty 925X-T2 problem
Bluenile
I sent this to tech support. If you guys have any suggestions that'd be great.
Hello
I recently flashed the bios of my Lanparty 925X-T2 motherboard with the 2005/01/13 update using diamond flash image. After Clicking the exe and formating the drive I restarted the computer. I set the bios to boot from floppy and saved and exited. It then restarted. It installed without any problem. I followed the instructions to eject the floppy and hit F1 to reset it. It resest. Nothing came up on screen. My floppy drive didn't didn't start up. My Harddrive didn't spin. The only thing that came on were the fans and the LED's and the powersupply.
I gave it a couple minutes to make sure there wasn't a problem. its been 30 minutes.
Please Advise
Thankyou
(name)
:( sounds like a bad flash man, isn't much you can do other than RMA the board, hopefully someone else with actual experiance with the board can chime in, but it doesn't sound good. Try clearing the CMOS using the jumper or pulling the battery, but other than that, i don;t think anything can be done.
So everything is working now. Had to clear the cmos. Im both impressed and depressed about dfi's techsupport...
They still haven't responded to my email.
When I called tech support this morning and gave them my spiel. Guy told me to reset the cmos gave me detailed instruction and everything.
Funny in that resepect. Thanks for your quick reply though!
I got a reply from them via email the next day. Maybe yours just got misdirected? The dfi-street.com forum is also very useful, plus a lot of things have already been asked and answered there.
The Orange It Burns The Eyes!!!
heres what gmail says on the matter...
techsupport@dfiweb.com
Technical details of temporary failure:
TEMP_FAILURE: Could not initiate SMTP conversation with any hosts:
[mail.dfiweb.com (10): Connection dropped]
thanks for the link though. It should be helpful if anything else conks out.
