Lanboy + Xp90c = ?
Bluenile
does anybody use a xp-90c with a Antec lanboy case? Does it cut off flow at all. does it block the back fan?
Thanks
Thanks
It kind of blocks it but seems to work fine. Just make sure the back case fan is in before you mount the hsf. its possible to do it afterwards but took me like 10 minutes.
