lanbox lite + h50
rontruong
hello guys,
I'm planning to mount my h50 and the radiator onto the side window. Just wondering if anyone has the exact specs on the mounting holes or the geometry? that'd be very helpful...
if not i'm going to go ahead and measure it and model it up on CAD.
I'm going to mill at my schools machine shop so it fits the case flush like the original screen... and to top it off, I'm going to put one of those spider man or something else grills for the 120 mm fan.
Anyone got any suggestions or tips?
This shouldn't take long, maybe a hour to measure and 15 or so minutes to cut.. it all depends if i'm lazy or not.
also anyone interested in one as well?
Mounting holes? It's the same as a 120mm fan just smaller thread on the rad itself.
