LanBox + ATI1950Pro
W6FO
The ATI 1950 Pro measures out to right around 9.5" which will bring it real close to the board edge on a uATX board. It should fit, but I am worried about the PCI-E power connector and if there is room for the plug between the board edge and hard drive cage. Most manufacturers are using the ATI reference board and this means the power connector is in the middle of the board not up at the top where it belongs. I see there is space between the board edge and hard drive cage but I can't tell just how much.
LanBox owners, what's your consensus?
Thanks
- JT
My Lanbox houses an 8800 GTX, so your ATI 1950 should fit as well.
