I recently upgraded one system at home and now have the following setup:
Cable modem to 4 port 10/100 switching router, then out to 2 systems. One system has a 10/100 NIC, the new one has 2x 10/100/1000 ports.
I would like to keep them both through the router for the internet connection as it has a firewall in it. I also want to utilize the gigabit connection for the LAN side. Basically buy a 10/100/1000 NIC for the second system and get or make a cat6 crossover cable to connect the 2 systems. This would leave 2 NICS in each of the systems.
Why, money. The router is perfectly fine and spending $100 for a new one vs $25 for a NIC and some cable to get a gigabit lan seems wasteful.
Can I make this work? Some setting to allow external traffic over the 10/100 and local traffic only over the 10/100/1000? The router has DHCP so I can set a different NAT address for each card.
Thoughts comments questions concerns???
Thanks
Timmy
Thanks
Timmy
