LAN help with Gigabyte E45 DS3L
Koko56
BIOS sees the LAN connection and tests it to be 100Mb/s and basically sees it. Then when the computer boots into Vista 64-bit the LAN light on the connection is not on or even if it is there is still this thing: device manager says that the device is not working.
I have little idea as to why that is as and any help would be good. :p
EDIT: Erm... so... drivers... :p
I might have been relying on Vista a bit too much. I did not install anything from the mobo CD with drivers etc. Now I've go tthe drivers and the internet is working. Ooops.
