Lan Gear Da Box question
DamTheMan
What are the differences between the blackheart and the classic models?
Also, what kind of fans does this come with and what are needed?
Thanks!
AFAIK the Blackheart is anodized black on the interior frame, where the classic is just bare aluminum.
I think the case comes with 2x 120mm fans and 1x 92mm, with an optional 92mm slot.
Dont get the window version. Because of the way the top cover has to be inserted downward, you will get scratched all over your window.
And even with a window, you wont be able to see much of the black paint inside. So the classic seems to be the smarter choice. But trust me on the scratching part.
Thanks for the input, wasn't considering the window though as my friend doesn't like windows.
Is it easy to remove the window and replace it with a mesh?
