Lan broken on mobo?
triarii3
Hey guys, i just built a new rig. using the GA-PH67A-UD3 and i5 2500k. the problem is after logging into windows my internet will not detect the ethernet cable. The ethernet cable is coming from the router to the motherboard. I even switched another cable to see if its the cable that's broken. but no, nothing, like i never even plugged anything in. Now i am questioning if the LAN is broken on the mobo?
any suggestions?! plz help
Did you install the drivers? The past two motherboards I have used required I install the lan drivers from the disk, as Windows 7 didn't install them.
Go into Network and Sharing Center>Change adapter settings and see if your wired ethernet adapter is listed there. If it is, does it say the cable is connected or disconnected? If it's connected, double-click on it and see what it says under IPv4 Connectivity.
On my UD4 I had to install the ethernet drivers following loading Windows 7. It was kind of a trip to have new hardware that Windows 7 didn't have a working nic driver for.
Do the LEDs on your network ports light up? If so, the hardware is probably working ok. So it most likely is a software issue.
it might be driver problem, or it could be the plug has bad contact. also, make sure you have your router set up correctly to connect to the internet.
you might want to go to command prompt and type in "ipconfig" to see your network status first.
It's DEFINITELY A driver problem.
I've seen the same thing happen on my UD5, and it ONLY happens in windows 7.
Basically, after loading windows, it sometimes says that a network connection couldn't be detected or something. When this happens, the green light of the port is completely off. But the orange blinking light is on.
After awhile, it usually just appears on it own, by itself, as if nothing ever happened.
This NEVER happens in windows XP. The network is detected and works perfectly right away...
If it's new then it most likely is a driver problem or the onboard LAN is disabled on BIOS (or perhaps EFI), check your BIOS settings.
I've had experience about three years ago when my new mobo's onboard LAN was broken, so I RMA'd it.
You mentioned that your Internet connection does not detect the network cable. Do you have a network connection without Internet or no network connectivity at all? These are two distinctly different issues.
Posted via Mobile Device
