SkaarjMaster
- Jan 31, 2002
OK, the first time I used them on a 92mm fan they were fine. I held up the MB by the fan and it held great. Well, as you all know, my Dragon2 MB doesn't work and I've hooked it up a second time and the clips aren't holding and keep coming out of the holes. I've tried bending them back and they still seem flimsy. Anyone know what's up with this and should I thermal adhesive the fan to the HS carefully as well as try the fan clips as soon as my new Asus MB is working properly and I have stuff installed properly? I've also heard if you install the fan clips backwards, they might hold better. Anyone know exactly how this is done?
