Bipolarbear
- Dec 25, 2008
Hi all,
Ive got a question for all lanbox/lanbox lite owners.
Like most of us who overclock in these sff systems the overriding concern has been heat. At the moment Im running a low vid g0 q6600 (1.15/1.12 load @ 3.015ghz) on a DFI Lanparty JR p45 in a lanbox lite. Have been very happy with everything so far, the overlocks been rock solid (440fsb, ram on a 333/800 divider (I think, writing this at work) running at about 1050ish).
Only mods Ive made thus far have been replacing the dinky Thermaltake 60mm fans at the back with two higher flowing units (23ish cf/m). At the moment system idles around 45-50c and prime95 loads at 69-73. Not dangerously hot but still warmer than Id like. I know that with aftermarket cooling I should be able to push this chip to 3.4ish, hopefully even 3.6 given its proven stable on such low voltages.
HSF options are, of course, limited by a) motherboard to psu height, which is about 110m and b) motherboard heatpipes and northbridge cooler.
At the moment the best options for my combination seem to be either the Zalman cnps8700, thermaltake blue orb II or Gemini IIS. Other options such as the Scythe Shuriken, NT-06e etc are certainly compatible but I dont think theyll deliver adequate cooling performance. Does anyone else have this specific combination and a better recommendation for what hsf to use?
Finally, Ive seen a couple of sugo sg01 mods where the psu has been modded to be placed over the pci slots area rather than the cpu area. Ive been looking at the lanbox and dont see a reason why a similar mod could not be performed on it. With a bit of creative (and probably maligned) metalwork, could have the psu sitting over the GPU area exhausting out of the case, leaving plenty of room about the cpu for a TRUE or similar.
Thoughts?
Thoughts?
