first and foremost, here is the new loop that I am building (my first ever)
2x Thermochill 120.3 or a 120.4 and a 120.2, idk yet
CPU block
Mobo block or individual blocks for NB/power circuitry
GFX card block
I'm looking to buy once and forget, so I am willing to spend a little extra moolah to get something high quality that will last through multiple loop changes (if needed)
I've decided to go with the Laing DDC 3.25 pump Now I'm looking for a top for the pump. I have a couple questions for you guys.
1: One pump or two?
2: Best top for the Laing DDC 3.25 (or a top for 2x pumps if needed)
3: EK DDC X-RES Top 140 was the top/res that I was looking at. What's the performance like for that top?
4: Anybody know of anything like that out there? I'm looking for a top/res combo because I'm getting a MM case and I don't want to mod a $400 case (but if you can't swing it, no biggie) with G1/4" threads to I can use comp fittings
I'm thinking the EK Waterblocks EK-DDC X-Top Rev 2 - Acetal with Bitspower Matt Black Male to Male G 1/4 Fitting connecting the top to a EK Waterblocks EK-Multioption RES 400 rev.2 is probably the best of the best but I wanted to see what you guys had to say (also if there was anything cheaper but still same performing)
thanks in advance guys
CPU block
GFX card block
1: One pump or two?
