grandpatzer
- Feb 24, 2010
Before putting case together I carefuly adjusted speed to the lowest noise that could push water though system.
The pump is noisy as hell, why?!
The pump I cut out 3 thin bits of tygon and put as feet, I screwed in the pump to the bottom of case and put 2 thin tygon bits under screws as padding.
There is about 15cm air bubble, It is impossible to bleed unfortunately.
