Hi. Figured I'd start my journey here by sharing one of my builds.
This is my budget priced build I made for my mom in 2010 december with mainly stability and silence in my mind.
Main use of this build was and still is to act as a DVR and spider solitaire
I'll put the as of now (23.3.2012) specs here:
Case: Cooler Master Centurion 540
PSU: Seasonic S12II-330w
MB: Gigabyte GA-MA78GM-S2H
RAM: 2x2Gb DDRII/800
CPU: Athlon II x2 240 (stock & volts lowered to 1.31)
GPU: Gigabyte HD5670 1GB DDR3
DVB: Terratec H7
Cooling isn't exactly [H]ard but more than enough for this build.
CPU has an Arctic Freezer 7 Pro Rev2 with stock fan and case has 1x120mm 800rpm Slip Stream as intake and 2x80mm Arctic F8 Pro PWM fans as exhaust.
Intake fan is spinning at 12volts and cpu+exhaust fans are spinning at 30% controlled by speedfan.
So let's go through some history just for the heck of it..
On July 2010 I was browsing the finnish online hardware store (Jimm's) auction section and came upon this reasonably priced AM2+ microATX board.
I didn't know what I would do with it but I decided to buy it on a whim.
It was the Gigabyte board I mentioned earlier in this post and I ended up paying 59 for it.
I received it and stored it till I find some use for it.
Originally I was planning to use it as my secondary computer.
Months passed by and the board collected dust on my shelf.
Then came late October and I found out how much I'm getting tax returns.
While I was browsing mindfactory.de, a german online store I came up on this reasonably priced Hama Media Center remote control.
And from there I got the idea, give my mom one of the most useful christmas present I have ever gave her.
Ended up ordering rest of the parts and there we go, the first version of my HTPC build.
GPU back then was a GT220 from Gigabyte and the HDD was this old and slow 160GB IDE made by Western Digital.
The case I had back then was this crappy Compucase 6T18BS or something like that. Couldn't find any older pic than this, also bad angle
It was a nice build. Low temps and noise and on top of that, very stable. It was spending most of it's time idling and up time was constantly more than 2 weeks.
But in [H]ard load it was a bit too noisy and in general the hdd was SO slow.
I had three 1Tb hdd's in my main rig. Decided to move all the stuff from one of the drives to the other two and put the empty drive in this build.
It is WD1001FALS drive, a Caviar Black (my best drive lol), which I bought fall 2009, power on hours count 17.3k right now and not a SINGLE error. I expect this drive to last many years
I didn't bother with reinstalling Win7 to this new hdd so I was going through my options.
Ended up using EASEUS Partition Master 9.1's "Upgrade system disk" function. It was a painless procedure and after the data copying process was done I removed the source drive and rebooted the computer and it was presto. Correct partition letters and everything worked like before.
System reboot time from desktop to desktop went from 2½ minutes + 2 minutes of loading after desktop appeared to 59 seconds and loading was done when the desktop appeared.
Success!
So if you're still with me, you might wonder how did I end up with this HD5670 I have in it right now? The Gigabyte GT220, which I originally bought for my main rig to act as a PhysX card, decided to drop dead and I fired up an rma to Jimm's from where I bought it. Asked if I could get something else in replace if I pay the difference and they were okay with it. After some browsing I ended up getting the Gigabyte HD5670 just because it has the same cooler as the GT220 had, which is DEAD SILENT, and I paid 10.
10 not that bad for such a jump in performance and image/video quality don't you think.
What else is there to do now when I have stability, very good video quality and relatively silent build? Upgrade the case of course to make it even more silent and to get even lower temps
I had this CM Centurion 540 laying around for like a year, didn't know what to do with it and had it FS for the past 6months. So couple weeks ago I decided that I'll do an organ transfer to this build. Ordered 800rpm Slip Stream from Jimm's and onward we went.
Before and after pictures. From these you might see why I wanted to upgrade the case
And here's the temps just for the heck of it.
That's about it.
Most of the noise right now comes from the 800rpm SS which I might drop to 7volts
Wonder what component will produce the most noise then
DVB: Terratec H7
Success!
That's about it.
