scottatwittenberg
- Apr 10, 2002
I just set up a LaCie Enternet Disk Raid. http://www.lacie.com/products/product.htm?pid=10877
overall it seems pretty straight forward.
when you create a user, it adds a folder for that user into a "homes" folder. It also gives that user access to the "public" folder.
So here is the problem. I want to back that whole storage raid thing up to a 1 tb usb drive.
I can't find way to get access to the root of the "homes" folder and thus all of the users folders.
you can't edit permission on that folder.
Our whole intention was to be able to backup all of the contents of this thing, and it doesn't seem like they, LaCie, have thought of that. it seems that they designed it as a device to back up computers on a small network to, as well as share files.
So if anyone knows how I can get access to root of the "homes" folder it would be very helpful, otherwise i am going to have to create a "share" for every user (about 10) and give them each permission to their own share, as well as giving an administrator group permission, and using a computer with admin permissions to back up this to an external drive..
cliff notes:
- how can i back up the entire contents of a LaCie Ethernet Disk Raid 2TB running raid-5 with one fail-over drive (total useable space, 1tb) onto an external 1tb usb drive nightly?
Thanks
cliff notes:
Thanks
