I have a LaCie Bigger Disk 1TB Hard Drive (300875) and yesterday out of the blue it died. When its turned on the lacie beeps for 30secs and I seems like its trying to access a HDD. I have no idea what beeps are..I tried to look on inet to find any info about the beeps or the drive for that matter. But like lacie support there is very little info out there that is useful.. I am recovering the data via testdisk but I m still not sure what the problem is. I have a spare lacie and i switched the hdd and same probs in the other lacie so am pretty sure its a hdd. Also when i first noticed the prob windows XP (sp2) had a popup that said something to the effect that it had a problem with the lacie and a write error..so when i rebooted winxp went into chkdsk and was trying to fix MFT..and it was stuck on saying "Inserting an index entry into index $0 of file 25". Comp wont boot with the lacie on..so have to turn it on after i get into windows and there it gets a drive letter but instead of showing the volumbe label in windows explorer it show up as Local disk and when I try to acces it says I/O error..so I want to know if there are good forums for lacie support, if some1 has ne idea of what tools i can use to diagnose what hdd it is or is it just a corrup MFT..ne input will be very helpful and appreciated..
sorry i know the writing is a mess but i m at work and just wanted to throw this up here to get some ideas when i get home..thanx again for any suggestions..will clarify once i get home if needed
