I am running Win-XP-PRO-SP2 on several computers. Small home network. I want to be able to remotely connect to them with my laptop from across the internet.
In the event log I find a warning
It seems getting a certificate is complicated but I can use pre-shared keys instead.
At this point I am stuck. I don't mind using certificates if I can get them easily, or pre-shared keys if that solution is easier. I just don't know how to do either.
Any ideas?
After some looking around I find this page http://technet.microsoft.com/en-us/library/bb742553.aspx where some of it is explained.Event: 20192 - Source: Remote Access
A certificate could not be found. Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate. No L2TP calls will be accepted.
Explanation
This computer cannot accept Layer Two Tunneling Protocol (L2TP) virtual private network (VPN) calls because it does not have an L2TP computer certificate installed.
User Action
Install a computer certificate for L2TP VPN connections on this computer.
Any ideas?
