R0achTheWarHero
- Jun 9, 2007
edit : This spyder2express calibration sucked because the gamma (2.2) is too dark for this monitor, I put a calibration with 2.0 gamma in the official L246 thread calibrated with spyder2pro
Wow, you earned the right to be the first person I have ever set to "ignore" on these forums. I hope you grow up but in the meantime at least I won't have to read your posts.
This piqued my interest, so I just checked -- turns out my LG has the same manufacture date (Feb 2007) and the same model number (L246WPQ) on the back. I got it from Best Buy about a month ago.Jesus, go seek some mental help or something. The brightness and contrast are labeled backwards in the OSD on my "L246WPQ", manufactured Feb2007.
look if what you say i true and i have no real reason not to believe you, then your monitor is very very defective.
There are absolutly NO black or white crush issues with the lg 24 inch monitors. It one of th very big reasons i purchased the monitor. and several others reported no crush issues to me before i bought the monitor.
I can also tell you that the only adjustment needed is 2 or 3 clicks lower brightness from the nvidia or ati control panel.
Thats it and you got color and brightness and contrast perfection.
With that said youve come here insultd everyone including me and you actually needed assistance to find out you had a bad monitor. That makes you an idiot., but im still helping you because well your comments dont mean jack to me. And i truely believe you cant get a better 24 unless you spend 1400+ for an eizo or nec s-ips panel.
Now with that said, you eiither have a very bad monitor or are just trollling and if trolling we can have you suspended or banned,
i would hope that maybe you realize how idiotic youve been and at least issue an olive branch of an apology,
I just tried both controls, and there's no question -- my contrast and brightness are definitely labeled correctly. So if there is indeed a problem it doesn't seem to be affecting all of the Feb 2007 L246WPQ monitors.
