does anyone have any info on the kworld atsc 340u? i've looked around on google, and all i get are customer reviews. i'm looking to get a usb tuner that i'll just mount internally in my case (cable/antennae will connect through the top vent on sg03). most important thing to me is qam, even though i'm not too sure how much it will benefit me since i use comcast (might go digital cable soon). i'm supposed to get some unencrypted qam through it or something. most of the other usb dongles that support qam are twice as expensive as the kworld 340u, and i'm wondering why. 3 users on newegg bought it, and 2 have been dissapointed by the channels they can receive. i'm wondering if anyone else has taken the plunge, and bought one of these. please share your experience if you do own one, and if you can compare it to other tuners you've owned in the past.
i'm still very noobie at this htpc stuff. i've got a vague idea about how tuners work, but was seeing if anyone had a short solid explanation of difference, if any, between unencrypted qam, and clear qam?
