Dirty Bint
- Apr 7, 2010
Hi,
I am trying to use a Latitude D630 docked in a PR01 port replicator with a KVM switch. The problem I am having is that the video signal is not displayed using the PR01 DVI port.
The Latitude D630 itself does not have a DVI port, however, when docked in the PR01, the port replicator has a DVI port that will display a video signal when connected directly to a monitor. When the KVM switch is placed in line between the PR01 and the monitor then the DVI signal is not displayed.
If the same setup is used with a different KVM switch, ie, a VGA enabled KVM switch then the video signal is displayed. I have tried using different DVI inputs on the KVM switch but without success.
Any help or advice to resolve the issue most appreciated.
Rgds
Dirty Bint
Rgds
Dirty Bint
