KVM Switch for 2 pcs (suggestions?)
IndyGSX
http://www.newegg.com/Product/Product.aspx?Item=N82E16817394047
Currently looking at that one, but was wondering if anyone had any recommendations based on ones they have used.
Things it HAS to have -
DVI In and out
Speaker
USB for mouse/kb
Softkeys would be nice, but I'm fine with pushing a button as well.
Some of the KVM switches I've looked at have had really short cables, 6' would be nice so I wouldn't have to have the cables all over my desk. Long enough to stealth the box would be super awesome.
I need one badly as I'm constantly working on other pc's and I hate bringing down my personal one so I can use the KB/Mouse/VID on it.
Any help is much appreciated! I hope this is the right forum as well.
Nate
Considering VGA (D-SUB) KVMs can be found for $10-$30, I'd suggest dropping the DVI requirement, especially since it sounds like you only need the KVM to work on other, non-permanent PC's. Its totally up to you, though. I haven't found the need for a DVI KVM myself, so I havent tried any (can't justify the cost). If you do get the one you listed, please let us know how it works. ;)
has to be DVI unforunately. I'm not going to mess around with adapters, rather just do it the correct way first.
Nate
Not sure how much the IOGEAR GCS932U would go for. I used one of their older MiniView KVMs (PS/2 and VGA I think) and really liked it for just switching between two machines on my desktop. The one I had, you could actually program the softkey option, in case the default conflicted with your software.
I'm currently using a TRENDnet TK-209K, which was on sale for $15. My TV/monitor is VGA anyway, so this works fine for me.
I prefer the hardware switch, as it seems like every program out there has realized that ScrollLock "isn't used", so they all use it themselves. I'm messing around with WoW multi-boxing software, and suddenly I'm typing on my FreeNAS console.
