KVM poor video quality
I just set up a fairly expensive Belkin 8 port kvm switch at work. When i fired it up, I noticed that the video had degraded somewhat. The monitor looked much brighter and washed out, slightly fuzzy and the text was not as clear.
Almost like when you go from 100hz to 60hz refresh rate you notice a difference, this defintely looks worse. I'm using a 21" dell trinitron at work with modest resolution 1024x768x32 @85hz due to my not so great eyes. What could be causing this?
How long are the cables you're using and is the KVM plugged in? I use a Belkin 4 port that looks good at 1600x1200@85 on a 22"
It's probably your cables. Unless they are thick, high quality cables, they are going to be pretty bad with today's high resolution and high refresh rate monitors.
