TwiceSliced
- May 1, 2002
I have a D-Link DKVM-2KU KVM switch (VGA, PS/2, USB), and it will only work if at least one of the PS/2 cables is connected to a computer that is powered-on. Furthermore, if one channel is only connected via VGA and USB and neither of the PS/2 ports are being used, then the device will not switch over to that channel.
Is there some kind of (powered?) PS/2 device I can plug the cables into so that the device will work as a VGA and USB-only switch? Any ideas?
I generally have some combination of a PC, a Mac, and a Dreamcast hooked-up to it, so I need one that will be able to work in even a VGA-only environment... Which is why I'm hesitant to purchase and try D-Link's KVM-221 KVM switch (VGA , USB, audio).
As it stands, if I want to use the Mac or the Dreamcast, I have to have the PC hooked-up and turned on.
Suggestions? Anyone?
