Originally posted by Aristarchus
$1.00 says that the schematic posted above won't work as desired.
The brutal fact is that "ground" on most computers is in fact the power supply ground. For those of us doing biomedical instrumentation, that makes for a lot of fun trying to get rid of 60Hz noise.... But I digress...
Anyhow, my suggestion would be to get yourself a DPDT (double pole, double throw) switch, connect one channel to each pole, (with the common being the signal destination) and connect all the grounds together, since they're more than likely at a similar potential anyway, especially if you have your two boxes plugged into the same outlet. If you're worried about differing ground potentials and you have powered speakers, (i.e. not headphones)tie each of the signal source grounds to the signal destination ground through a 1K resistor. This should limit any ground loop currents to minimal levels, unless the guy that wired your residence was completely incompetent...
Good luck, & don't blow anything up...
