Kvm cables 2.75 each
they don't look like high quality ones like belkin but good for home use for short distances.
I bought a 4 port at a yard sale yesterday for 10 bucks, so i need 3 more cables. for home and short distances.
its a keyboard, why do you need high quality cables!
ok, forgot about the monitor, but still, unless you are using a 1500 dollar 23" monitor, you will probably notice no difference at all :)
It really depends on your setup. If you are near any high frequency emf/rfi source, you can notice it on a $150 21" Refurb.
Newegg had a 4 port KVM with 4 set of cables for $15.99 not long ago. It is $33.99 now. This one.
Buy.com has it for $24.95 right now. Here
The one I got from buy.com (IOGear Miniview 4 port with 4 set of high quality cables up to 2048x1536) was like $15 after rebate.
The quality of the monitor cable is critical, and not only if you're running a big, expensive tube. Low quality KVM cables (and I've had a few) introduce noise into the video signal such that anything about 1024x768 resolution is total crap. And the lower quality the monitor, the crappier it will look.
Not saying these are that bad, just clarifying the issue of cable quality in general. :)
