KV8 error code 2.6 and beeps during gaming plus other chaos! HELP!!!!
ffactoryxx
Ok so i installed my
KV8
3000+ a64
corsair value ram 1gb
350 watt antec ps
9800pro
Now first things first. When i first booted before os installation i got checksum error. upon reboot that went away and windows loaded fine. Rebooted again and saw cpu changed etc. Loaded failsafe defaults and then fine.
Next i played Doom 3 and after some time i got not a siren but a constant series of beeps and things. Didnt think about a sequence, just beeps constanly long and shorts blah blah blah. Exited and everything was fine. Next i checked my temps and the temps are 50c idle. Even with a aftermarket $30 thermaltake k8 boost with arctic silver. When i boot to windows the LED code shows 2.0 then after a bit go to 2.6 or 26 with the 6 flickering to anothr number faster than i can see every second or so. Whats the problem. Could my heatsink not be tight enough?? because the plastic hood over the mosfets stops it about 85% locked down. Seems tight though. What the hell is going on. Can i take that hood off? Any ideas
