UnknownSouljer
- Sep 24, 2001
My Dad is using this what is now antiquated board, that I used to build his rig about 4-5 years ago.
In any case recently he decided to upgrade his ram, but not just upgrade it, max it out.
So we went onto newegg and bought 3x Mushkin 512MB PC133 CAS3 Ram. Lifetime warranty all that jib-jab.
The maximum the board says it will take is 1.5GB (just covering bases stay with me), so the amount of ram purchased should be correct.
When population one slot it works perfectly, but two or more makes windows restart repetedly. I tried using the most concervative settings in the BIOS (disabled all shadowing, turned of dram interleave etc), I ran everything as slow as possible, updated the BIOS to the latest version, and the like. Sometimes eventually it will fully boot into Windows and then be perfectly stable (can put a load on it etc, and work with it constantly... not that what my dad does with documents is really intensive). However restarting or turning off the computer starts the same cycle.
So I suppose I'm wondering if any people with this blast-from-the-past board had problems with RAM population, and of course if there are anyways to fix or aleviate the problem.
Full system specs:
Abit KT7-RAID
Duron 650
1.5GB Mushkin PC133 CAS3 Ram
S3 Trio/64 PCI graphics card
no sound card
US Robotics V90 56k Modem ISA
Generic Ethernet NIC
random HDs and optical drives.
Full system specs:
Abit KT7-RAID
Duron 650
no sound card
