KOSS PRO - 4AAT vs Sennheiser hd497
HD-497 has a much better and wider soundfield. (Instriment placement.) It also has a much flatter graph. (Sound can be played without any dips in volume at cirtain frequentcies.) Ultra transparent! (Means they sound more like speakers and live than headphones and in your head.) They are about a pound lighter, louder, detachable cables, more comfortable, and can be played without a headphone amp since they are 32 ohm. The sound more natural too.
Koss 4AAT has much more defined bass. 20oz! Really heavy! Better constuction, more adjustable fit, sealed, I think, and have nice and nearly indistructable cables.
I'd choose the Sennheiser if you need more quality and transparentcy and don't feel like downing $50-150 for a headphone amp.
If you like rap and have money for an amp then why bother getting 4AAts when you can get some real studio monitors.
They're two completely different beasts. The Koss Pro/4AAt is fully closed, boomy, honky, nasal, terribly inefficient and ultra-heavy -- all too typical of full-sized headphones from the 1970s. The Sennheiser HD497 is open, airy, clear, slightly plasticky, very efficient and realtively light-weight. Both headphones can be uncomfortable: the Kosses due to their excessive weight; the Sennheiser 497s due to their excessive clamping force.
